Re greasing sealed hubs!? (Blazer upgrade)
83beater
118
49
Maybe try making an extension piece using a piece of old steel fuel line or something similar tubing to be able to fit between there. Kinda like the guy on the B-body forum did.
And again, it depends on how accessible the ABS sensor end is.
I went to chafazone (autozon) and they have a greas needle adapter. Looks just like a needle to put air in a sports ball? Wonder if that should be the easiest .I just under my car .I can! Get to it
12,178
9,799
It sounds like that apparatus may take you awhile to pump a sufficient amount of grease in the hubs.
If you can post a pic of what it looks like, or a link to the product.
83beater
118
49
It's this one
12,178
9,799
JAMCAR223
1,853
5,507
Houston, TX.
Just attach a zerk fitting to your grease gun, and then slip a 1ft. section of vacuum hose over the zerk. Fill it up... Done.
12,178
9,799
True .thinking to snip the end .if not just gonna get a carb hose that fits in the and a zink fitting on the other end lol
....or you could do what the guy in the classB link did. Using a small piece of tubing, or pipe and screwing a Zerk fitting into the end. It looks like the tubing he used had the end closed off and drilled a small hole near the end for the grease to escape.
James ^^ pretty much presented a simple solution. Use a piece a hose and attach a zerk fitting. Attach it to your grease gun, put the end into the ABS port, pump it up and be done with it.
It shouldn't be complicated.
oldsmobile joe
2,067
3,053
mpls
i have a some rather stupid questions to ask.
why do we need to add grease to a sealed bearing?
where did the grease go?
if i pack in too much grease, what will happen when it heats up and expands?
should i make a little dip stick for it, so i can check to see if its low?
24,218
Honestly, I did it because I couldn't stand to have a cut-off plug in the hub. A Zerk fitting made more sense, and more grease- just cuz. No rationality whatsoever.....
