Adjusting the upper control arms will move the rear left to right as needed. Measure between the tire and frame for a good centered location.
That’s a great video!Just did an 8.8 swap in my 85SS with adjustable uppers. You can adjust the rear upper control arms and it will pull/push the rear end from side to side. I measured from the inside of the rim to the frame rail to get it basically the same both sides. Then set the pinion angle. This video helped explain things.. I see you have adjustable arms in that package.
