rear daytime running lights not working
jkponce
49
45
Lake Forest
www.facebook.com
My headlights turn on, all turn signals turn on, all emergency lights turn on but the rear tail daytime running lights don't turn on.. i can't figure out why they don't turn on anymore
There is a ground wire in the trunk that could be your problem. It looks like an eyelet with a clip built onto it, the clip snaps into a square hole and the screw holds it down. I think it's on the left side at the floor. Find where the harness goes out to the lights, it will be near there. You may have to pull back your trunk trim to see it.
Turns out that was the problem, thank you so much! i had a loose wire
