so im swapping a lsd out of a camero into my cutlass my question is do i need to swap pinion gears aswell seeing as im going to a 3.40 lsd from the stock rear gears in a 79' cutlass?
BaggedCutty said:so im swapping a lsd out of a camero into my cutlass my question is do i need to swap pinion gears aswell seeing as im going to a 3.40 lsd from the stock rear gears in a 79' cutlass?
That should be 26 spline. I used one from an '87 Camaro and it was 26 spline. Another thing to be aware of is that most install kits (bearings, shims, seals) are for '81-up 7.5" rears. The earlier rears, like your '79, used a different outer pinion bearing. As others mentioned, do lots of studying before you dig in. It'll save you a ton of headache and money.BaggedCutty said:Its a 85' Camaro Z28 I was told they are the same if not can I use the axles out of the Camaro?
