Rear disk brakes
Here's a pic of the brakes I'm working with.
The rotors, calipers, caliper brackets, and the axle bracket off a 2wd blazer are what you are looking for. The only difference between the 4wd and 2wd brake setup is the bracket that bolts to the axle and the rotor. The 4wd setup hits the frame and the 2wd works fine. I'll take a pic in moment.
Ther rears are a bit hard to see. Here are my fronts also.
Here is the rear. I did have to make a shock re locator bracket. Just a piece of angle iron with two holes drilled in it.
