There are a few posts about how to do the Blazer rear disc brake swap, the blazer swap is cheap if you live outside the rust belt because you can find most of the parts at a local junk yard.
What is everyone's thoughts on converting from drum to disk on a 83-88 Monte SS? I plan on changing out the rear end out anyway how much harder would the conversion be? Other than the straight forward parts that need to be replaced what else is needed? Would i need a new master cylinder?
