rear end + disk brakes
2000.malibu.ls
1,311
Lake City, Florida
ok assuming i can come up with a rear end and disk brakes from something out of our junk yard, what would you recommend I put in? I guy I work with has a welder and plenty of tools, but im only a high school student and I only can afford to spend about 200 bucks on parts. We have a f-body at the yard right now, I dont know what the rear end looks like but it has rear disk brakes, could I use that whole axle on my regal? what about using the front disk breaks? Of course this stupid thing has been sitting on blocks for 5+ years so i of course would get new pads and slotted rotors. Is this job doable?
also what cars came with sway bars so I can look for them when Im out junk yard shopping in other yards?
there are no good bolt-ons for the g-body rear. you can use 92-96 f-body brakes with some drilling and cutting, which works well.
or you can get brakets to mount 80's caddy eldorado rear brakes. they're not all that good though.
the f-body rear is not a bolt in. some of the a and b-bodies are close and can be used with proper control arms.
sway bars--i think there are 2 rear sizes 3/4 and 7/8. pretty much any model could have one but the performance models are the most likely. obviously if there are 2 sizes you want the larger. i'd find the codes that indicate an F-41 package and pull the front (1 1/4) and rear bars and the chassis braces.
Re:
2000.malibu.ls I don't mean to steal your thread... Its hella old anyway.
megaladon6 said:
...or you can get brakets to mount 80's caddy eldorado rear brakes. they're not all that good though...
Hey megaladon6 what do you mean that the caddy brackets are not all that good. I have a set of 79 Seville calipers and brackets and I'm thinking of using the Thirdgen F-Body Rear Drum Brakes to LS1 Discs process as a guide to put them on my 79 Malibu. {http://www.thirdgen.org/ls1reardisc}
Do you have any suggestions for me?
Being familiar myself with being a poor high school student trying to spiff up the car a bit (bought my 442 at 17), my advice is to save your money.
Chances are that $200 could go to a lot better use on any number of areas on your car.
actually i meant the brakes aren't that good, not the brackets. the caddy calipers don't have the greatest clamping force IIRC, and they are HIGHLY prone to the p-brake sticking and the pistons getting stuck from rust.
my suggestion is to use f-body brakes. the good news is that some companies are finally starting to make bolt on brackets for the G rear.
how far from CT are you? i have a set of 94? camaro brakes with the brackets and everything that i no longer need.
