Will the rear end out of a 1979 Chevy Monza fit into the back of a 1984 olds cutlass supreme? I realize the Monza is only 4 bolt wheel pattern, but other then that is it wider/skinnier then the one in my car? Found one with 3:08's and a rebuilt posi for $100
Thanks
Justin
IMO you would be better off finding one off a g body... Monte SS rears are usually pretty cheap although they are 7.5 & 7.625 but they do have decent gears and may be optioned with a posi.
I think the posi will work, but I seem to recall something about the gears not quite being the same. And no it's not worth it to try to use the whole thing.
I kinda remember something about that. I had trouble finding gears for mine because most they were all for 'all 7.5s except Monza'. But I forget the reason.
