Ok so I recently just finished doing a ford 9" swap on my 81 monte street /strip project and I ran into a small issue. the housing I used is 60-3/4" wide which is wider than stock and thats not an issue cause I plan on just using different back spacing to make up for the extra length. However the housing (allstar performance) uses a 2" off center pinnion which allows for equal length axles. I know the pinion yoke lines up with the transmission tail stock just fine and the drive shaft has lots of room. However the problem I have run into is that because the center pot of the housing is 2 inches to the right my stock sway bar will to fit cause it contacts the housing. Does anybody know of an aftermarket rear sway bar that will give me a little more room to clear the housing or will I need an anti-roll bar thats adjustable to work? Any input is appreiciated.
