Rear WAGON Door QUESTION???
Juveteach
10
57
Concord NC
www.cabarrus.k12.nc.us
Hey guys,
I have a 1979 PONTIAC LeMANS SPORT WAGON.
That being said, I was wondering if ...ALL THE GBody WAGON DOORS are the SAME???
I guess that goes for the fronts as well??
I have some rust in the rear doors and I was wondering if a Chevy Malibu door would fit my PONTIAC??
Thanks,
I'll be watching
Did you find the answer?
Yes I did.
The doors are the same from what I have read. It is just the window frames that are different. I may just leave the larger rear vent windows in it...or plexiglas the entire thing. Who knows...
Just to reiterate the subject. Pontiac wagon doors will fit Chevy and vice versa. They share the same body lines. Buick and Olds will fit each other,.. 4-dr sedan front doors are a direct fit. The rear sedan doors will basically fit, but the window frames would need to be changed out.
You certainly have the option to remove the vent windows(and door glass) and install a full piece of Lexan. You would need to continue the glass run channels to accommodate the larger replacement Lexan, glass, or Plexiglass... pretty simple.
Reactions: liquidh8
