Rear Wheel Spacing
87GrandPrix
129
Michigan
The Distance from the edge of my tire to the wheel well is 3 Inches, What size wheel spacer should I put on. Im thinking 2.5 Inches which would be 85 dollars. But Im having second thoughts for 2.2 inches..
Just my opinion, but I don't trust the safety of any wheel spacer thicker than about 1/4". Before I spend good money on spacers, I'd be looking at wider wheels.
Bill
My thoughts are this.
NHRA allows the use of 1 and only 1 spacer, what is in the link is an adapter.
Not NHRA legal. You may never race it, but you gotta wonder why they are outlawed.
I had a customer that wanted me to use them on a 500 hp Trans Am, I refused.
I ended up pressing the "studs" out of the adapters and using them as spacers.
Also upgraded to longer, thicker, grade 8 studs on the car.
It has been fine for years now.
I have a (insert dyno hp here!) HP supercar. Can I still use the adapters safely?
Our adapters have been run on pro-stock cars without any problems. They performed flawlessly. Its doubtable you'll be able to stress the adapters any further.
http://www.skulte.com/info_pages.php/pages_id/3?osCsid=412f776436d5e6ea96051e9f2ec65c42
if you buy quality adapters with the proper hub bore and lip you'll be fine. plenty of guys use them racing and auto-xing which beats on them pretty good.
Skulte's description of their adapters speaks volumes. Machined from 6061 T6 aluminum, they likely have a strength factor very close to mild steel. Adapters I've seen in the discount parts stores look like they're cast, not machined from billet. No way am I trusting a cast aluminum part on my car.
Bill
