I am doing a 5.3 LS swap for my 85 cutlass. I will also be using a 200-4r transmission(built up of course). It will be used as a street car. I am putting in a little bit larger cam(nothing wild), and home porting the heads on the 5.3. My question is with the rearend. Right now it has a non-posi with 2.14 gears in it. I want to go with 3.73's and a posi. This is a budget build, so no moser 9" for me. I can get a brand new 26 spline auburn style posi for $370.00 bucks, or I can use the 28 spline used auburn I have out of camaro, and buy new moser axle shafts that fit. I figure the cost would be about the same, but I would have a brand new posi unit, instead of a used one. Would using the 28 spline axles and posi be any stronger than the 26 spline unit and axles? I've been told the week point of these rearends is the ring gears, since its so small. Ideas?
