Rearend Swap to GM 12-Bolt
GotSomeRust
20
South Dakota
I'm swapping out the stock rearend of my 84 Cutlass for a GM 12-Bolt. The car is going to see the strip a few times. I'm not real good with knowing what's what. I have the 12-bolt rearend. Can someone tell me exactly what I need to swap the rearends? If you could point me to part numbers, a kit, or anything else in Summit Racing, Jegs, or wherever, I'd appreciate it. Thanks...
79malibu
251
south dakota
rears
i don't know about rear swaps but what part of SD you in?
79malibu
251
south dakota
rears
rosholt, in the corner with ND and Minnesota
rikbar
7
sorry can't help with your queston :oops:
but just wanted to say "hi" to a couple of fellow south dakotans
I am on the west side.
Sep 1, 2006
6,687
34
Tampa Bay Area
It all depends on what you got the 12 bolt out of. There are 2 widths of A body axles--64-67 and 68-72--, plus Camaro, Nova and Big Car (Impala, etc.) axles as well. There is also a 12 bolt truck axle too, but it is not the same as the passenger car axle! The Big Car axle also uses a 5 on 5 bolt circle as compared to the 5 on 4.75 for the smaller vehicles.
GotSomeRust
20
South Dakota
I'm not sure what it came out of. It was loose when I bought it. I'm assuming it came from the 68-72 era, but I haven't verified that. Is there a kit or what exactly do I need to get it under my car? Thanks
shotgun
1,067
81
48
Nort o Philly
Measure drum to drum should get you going in the right direction of IDing it.
Look for any numbers/letters stamped on the axle tubes.
After we figure out what it is,buy the SSM bar I have for putting a 12 bolt in a Gbody. 8)
GotSomeRust
20
South Dakota
I didn't get a chance to look for any numbers, but overall it measures 58 inches the tip of one axel tube to the other. 68-72 Chevelle?
bigdan
380
4
st-jean baptiste ,quebec,
58" from tube ends ...must be from a B body : impala caprice etc... too wide
your g body is 58" total width
