khan0165 said:I went thru my post again and I noticed I drifted off topic a little...
I mentioned that my build is very "old school", as in it's a simple way to get power from back when not many parts were available.
If you've done some reading, you'll notice that engine building today (compaired to back a few years ago) is all about efficiency now, rather than blunt force and bigger parts.
You can free up lots of HP from simply running better parts.
Getting some H-beam connecting rods, and better pins & pistons will help you rev quicker and higher. A roller cam, will free up some friction in the valve train. Valve springs are another area where people over-indulge and get springs that are too stiff, so look out for that. Port work also works, but if you're like me, and you're not too handy, even a gasketmatch port job will go a long way. Take a shot at polishing your ports and chambers. Running an electric water pump and a more efficient streering pump will take a load off your rotating assembly. You can beef up your ignition too with an HEI system, better wires, and maybe even a programable timing box (check out some MSD systems).
Good induction also frees up some ponies. Run a simple cold air system, even with some plastic ducting hose clamped to an old fashioned snorkel aircleaner. And if you're not worried about hood clearance, run a highrise-airgap-singleplane intake. You can even use a carb spacer if you're running a cowl or a tall hood.
anyways... that's what I wanted to add to my post... money permitting, take a look at what you can do, and look at ways to improve efficiency, rather than cramming in bigger parts.
Yeah I hear ya. The problem right now is I'm on a budget. As in a dont touch my good bottom end budget, throw in a decent flat hydro cam, used decent heads, and run it.
So far its looking like:
9.5:1
Vortec 906s that I'll probably polish up and gasket match, screw in studs, bigger springs
Lunati 60103lk
"Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,800-6,200
Intake Duration at 050 inch Lift 227
Exhaust Duration at 050 inch Lift 233
Duration at 050 inch Lift 227 int./233 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 276
Advertised Duration 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.489 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.504 in.
Valve Lift with Factory Rocker Arm Ratio 0.489 int./0.504 exh.
Lobe Separation (degrees) 110"
Edelbrock torker II
Summit 600cfm square bore
stock converter (for now depending on whether it stalls at 2000 or 2400)
megashifter and a shift kit to control el trans
stock 3.73 8.5 rear w/ 275/60 tires
Personally I think this will take me like 13.2-13.3
Getting an air gap would probably shave .1 or at the very least get me a better launch which may very well bight me in the *ss.
