Recommend a roloc disk for...
Tony1968
2,324
5,132
NW Indiana
Taking off undercoating in rear wheel well...
I like using the 2" or 3" roloc because they are easier to get into tight spots. Plus I don't need to remove much.
Thanks
melloelky
4,162
9,569
mass
how large of an area are you planning on covering with these small disks?
melloelky
4,162
9,569
mass
ok,go with the red.they're the coarsest by far but as long as you're not standing on the grinder with both feet you'll be fine.3m and norton red's the coarsest.
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,697
Spring, Texas
Mineral spirits or lacquer thinner should wipe undercoating right off and then you aren't grinding the metal at all. Less mess and better for the car.
Tony1968
2,324
5,132
NW Indiana
Good idea. I'll try that as well. But have to take off some paint because I need to weld in a patch
oldsmobile joe
2,067
3,053
mpls
i thought the brown rolocs were.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
I thought the green 36 grit were the most coarse...
