If the above post is true about now being made overseas then I agree, like I said when I was in the garage they were all US made, but that was seven years ago. All of the boxes I got from Rock Auto said made in the US on the box, if the other post is correct maybe they were old stock. I have a PST catalog if all this is true about Moog then I would buy the kit from them, it looks like all the stuff in that kit is decent. Opinions will differ on rubber vs poly, but what I have seen is poly CAN squeak, not always but can, also on a poly bushing the sleeve or shaft spins inside the bushing making the bushing a wear item, that is why the quality ones have a grease fitting in them. If you don't drive your car much they will probably last forever, but the original rubber ones on my car lasted 33 years 55,000 miles. Rubber bushings installed properly ( bolts tightened at ride height) will outlast poly ones. This is just my opinion, I have always done poly body and motor mounts and rubber suspension and have always been happy with the results, I have personally done this combo on probably 30+ cars of various makes, most of them customer cars, in the garage and never heard a complaint, but I did redo a poly bushing setup that was four years maybe 6,500 miles old because the car wouldn't align because of the slop in the lower control arm bushings, that was my 79' Camaro, but the theory is the same
