Im wondering if anyone out there knows if the supercharged 3.8l v6 from the w body buick regal gs can be longitudinaly mounted and if any of the older rwd transmissions will bolt up to these engines. if you dont know thanks for lookin lol 🙂
No blocks are way different sorry. 😢 They did put a 3.8 in some 90s camaros with a 4L60E that would fit but no supercharged.Very Regal Sedan said:Im wondering if anyone out there knows if the supercharged 3.8l v6 from the w body buick regal gs can be longitudinally mounted and if any of the older rwd transmissions will bolt up to these engines. if you dont know thanks for looking lol 🙂
tc1959 said:No blocks are way different sorry. 😢 They did put a 3.8 in some 90s camaros with a 4L60E that would fit but no supercharged.Very Regal Sedan said:Im wondering if anyone out there knows if the supercharged 3.8l v6 from the w body buick regal gs can be longitudinally mounted and if any of the older rwd transmissions will bolt up to these engines. if you dont know thanks for looking lol 🙂
There is no motor mount lugs on the transverse engine And the oil filter adapter would be in the way. to fit in a RWD body.Very Regal Sedan said:tc1959 said:No blocks are way different sorry. 😢 They did put a 3.8 in some 90s camaros with a 4L60E that would fit but no supercharged.Very Regal Sedan said:Im wondering if anyone out there knows if the supercharged 3.8l v6 from the w body buick regal gs can be longitudinally mounted and if any of the older rwd transmissions will bolt up to these engines. if you dont know thanks for looking lol 🙂
so not even with a t56 manual trans?
There is no motor mount lugs on the transverse engine And the oil filter adapter would be in the way. to fit in a RWD body.Very Regal Sedan said:so not even with a t56 manual trans?
W bodies are ft wheel drive,Holden's being rear wheel drive, are sold in Australia that could be a bit of a problem :shock:pontiac gp said:there is one RWD that runs a 3800 Series II L67 Supercharged engine that was run in the w bodies...the 1996-2004 Holden Commodore VS (series II)
tc1959 said:W bodies are ft wheel drive,Holden's being rear wheel drive, are sold in Australia that could be a bit of a problem :shock:
