Regal tends to dart on bumpy roads
I saw those also, but I read that they weren't very good for street use, due to no boots or weather seals on the pivots and in some cases requires frame trimming to work correctly. How the 275's fit is barely and Ideally I want to narrow my front rims and drop back to a 255 front tire, but I have yet to find a shop that I can research and trust with my rims(very hard to acquire).
Thanks for all the help on this. I thought that might be my issue and wanted to check.
My screw in lower ball joints didn't come with seals so I made some out of an inner tube and ss ties...another method to fix a bump steer problem is to heat up the steering arm and using a large adjustable wrench bend the arm up or down as required
