not sure how to remove the outside opera window moldings ! need help . want to stretch my vynl so i need to move remove them.thanks for any help i can get
using a heat gun very carefully and a putty knife. you lift/peel up 3-4 inched and then pull/stretch to what you want.then spray adhesive under neath .press and hold till dry.reattach moldingIf you remove the interior panels there will be some 10 mm nuts holding the moldings in place. The window is not attached to the trim. I'm not sure how you are going to stretch the vinyl causes it is glued to the roof
