86 El Camino 305, LG4. I've posted about this before a long time ago.
I don't know if these are the correct terms, but I've been calling it the smog pump. In any event...
There is a belt driven pump with a vacuum tube leading to this other thing, it's the first picture at the top. I'll collectively call them the smog pump system. I want to remove both. Also the line leading to the cat (probably getting a new one soon anyways) and the Air tubes to the exhaust manifold (I'll plug em) will be removed.
The one pump has some wires and vacuum tubes going to and fro. If I remove it, I can simply plug to vacuum tubes.. but what about the electrical stuff? Will my carb and choke be messed up if I unplug it all? Note, I do not want to remove the charcoal canister. That is staying.
It's a weekend and I'm home from the University of Delaware for Thanksgiving break, and I need something to keep me busy. 😛
