I have replaced the light pod with a gauge pod . I have changed the temp. sender and oil pressure sender . I am thinking that the voltmeter is bad in the gauge pod it never worked . the oil pressure gauge worked once. Today I attempted test the voltmeter I think perhaps it bad . I have located another gauge pod . I am thinking if it would be better to replace both with after market gauges. It will not be original but at the least they should work. i would like to know what some of you think about it. I am sure I don't want the a gauge pod on the a pillar
