The following write-up for replacing the power window motor by GP403 was a great help to me and can be found with a search but will post a snippet here of his method:
Well, the driver's side window motor finally went out after 26 years. lol. Was hoping it was just the switch but no luck!
Grabbed the body manual to see how much of a PITA this was going to be. Really wasn't as bad as I thought. I expected I'd need to remove the entire assembly but as it turns out the motor is a separate piece and just comes right out...
... but only after you drill out a couple holes in the door (!) to get at the bolts that hold the motor in!
![Rolleyes :roll: :roll:](https://cdn-0.gbodyforum.com/styles/default/xenforo/smilies/rolleyes.png)
Of course the hole saw bit I bought broke the pilot after 1 hole so I had to take the die grinder to the 2nd hole... :evil:
I took a couple of photos (will post later), but the gist of it goes something like this:
- remove the inside door panel
- drill out 2 or three ~3/4" - 1" holes over the bolts holding the motor in. The manual says three, but one was already accessible, there are a couple of little dimples that'll tell you where you need to drill. The bolts are located so there's no way to get a wrench behind there, and even if you did, you couldn't back them out. They were 13mm on mine btw.
- tape up your window, just in case, so it won't fall. Mine didn't move, but YMMV.
- pull the 3 bolts and drop the motor into the door so you can disconnect the wiring connector. I couldn't reach the plug until I did that, again YMMV.
- The replacement motor had a bracket so you could install it on either door, put this on the correct way. It also came with some other brackets and screws which I didn't need. Maybe they're for a different application or something. Put some grease on the new motor gear.
- pull the old motor out through one of the access holes and put the new one in. Plug the power back in, line it up and make sure the gears are connected, and then bolt her up.
- Take the tape off yer window and test it out. Hopefully it worked!
- Put your door back together again!
Will add photos to this when I get them off the camera...
