REV Classic 100 wheels
Dryer
5
I found a set of wheels that I want. They are REV Classic 110's. The problem is in a 17x9 they can only make it with a 5" backspacing. I guess I would have to run a spacer for them to fit on the rear. Correct? The fronts are the same way. 17x8 with a 4.5 backspacing. Is anyone running these wheels that can give me any insight on how to make these fit? They are going on a 88 monte ss if that help. Any help is appreciated, I'm ready t pull the trigger on these.
The 17x8 with 4.5 backspace will work in the front, that's what i'm runnig. The 5" backspace in the rear will most likely be too much, but with at least a half inch spacer you should be okay. I would recommend using a one inch adapter in the rear.
