The computer isn't the only thing lacking bandwidth in this scenario. I am starting to think I need to open a school. 😉
I’ve never seen the purpose of a MAF sensor, especially in this scenario. The air flow can be calculated from the VE, and leaks make the MAF completely useless. I’m sure his junkyard setups leak like a sieve everywhere, or I’ll guess.This is why i wanted to put in a MAF sensor. All the data!
Calibrated Mass air would make fuel tuning way more accurate in SD and you would have real time horsepower and efficiency numbers when you made a change like a cam or heads.I’ve never seen the purpose of a MAF sensor, especially in this scenario. The air flow can be calculated from the VE, and leaks make the MAF completely useless. I’m sure his junkyard setups leak like a sieve everywhere, or I’ll guess.
Regarding Mike’s thoughts, it irks me that he never pushes anything to the limit. Or at least to the edge. His S475 testing in built 4.8 short block p’d me off. Always stop at 15-18psi - why?????? Especially during the cam test.
I have to say though that I enjoy most of his crap, it sure as hell beats watching Big Brother, The Voice or the need according to a journalist lol.
I will eventually have one on the cutlass, just need to figure out how I want to make it happen.
This in a 3.5" post intercooler pipe.The challenge is always calibrating the MAF to the capacity of the combination. Tube diameter is an interesting variable, as is accuracy relative to turbulence across the sensor. Good times.
What I'm sure he's planning on doing here is pushing the motors to the limit with what he calls a "big bang test" and I'm sure he's taking things relatively easy right now to test out a few different things before trying to break the motor.Regarding Mike’s thoughts, it irks me that he never pushes anything to the limit. Or at least to the edge. His S475 testing in built 4.8 short block p’d me off. Always stop at 15-18psi - why?????? Especially during the cam test.
Nobody tunes off MAF, just Mike because he's a Mas*chist.What I'm sure he's planning on doing here is pushing the motors to the limit with what he calls a "big bang test" and I'm sure he's taking things relatively easy right now to test out a few different things before trying to break the motor.
He did end up pushing his 4.8 engine up over 27 psi before they had an ignition issue that they didn't have time to fix.
edit:![]()
Stock GM LS Engine - Big Bang Theory - Hot Rod Magazine
Stock GM LS Engine - Take the Stock GM LS Engine. We are trying to learn everything about it's limits and we will tell you the results. - Hot Rod Magazinewww.motortrend.com
also this video shows a few others he's pushed to their limits:
I'm imagining he's running in speed density, but if he's tuning off the MAF I'm sure the junkyard motor is sealing just fine in the areas where it matters since it was pulled from a wrecked car. valve cover gaskets like to leak on these though.
MAFochistNobody tunes off MAF, just Mike because he's a Mas*chist.
Unfortunately the only way to tune a 3800 with the factory pcm is to use MAF tuning. The VE tables only go up to 140 kPa on those PCMs.Nobody tunes off MAF, just Mike because he's a Mas*chist.
