pontiacgp said:it's a lifter that is wider on the bottom so the valve opens sooner and stays open longer...to use them you have to spot face the bottom of the lifter bores
pontiacgp said:and if your just asking about the installation they have to go in before the cam is installed cause they have to go in from the bottom
mickey-d said:Good call on the mushroom lifters, and thanks for explaining the deal on checking rocker ratios. You can also buy different length pushrods, and adjustable push rods to do the same thing as increasing rocker ratio's. Would they check that too?? ..........mickey-d :lol:
