Just a thought, did you point the temp gun at the thermostat housing, before the housing on the coolant passage of the intake and on the upper radiator hose? If there is a temp difference in that area I would say thermostat, what temp was the thermostat you put in? If it's 190-195 your engine will run a little hotter than normal, try a 160 or 180. The clutch fan doesn't work past 35 mph, it's designed to cool the engine at low rpm's, so if you get up to highway speeds and the engine is cooling down to whatever the temp of the thermostat is that you put in but at idle or in traffic in town conditions it heats up to 220 then I would start looking at the clutch fan. The black air dam should be there on this year and it does help a lot so if you don't have one I would start looking to get one or you could always upgrade to electric fans and a shroud. Also did you check the radiator cap? If your cap does not let pressure build up in the system then there will be no coolant flow to the back cylinders of the block and cause overheating issues as well. Good Luck.
