the jeep or the astro shaft won't fit on either 525 box...both 525 boxes have a 3/4 spline, the jeep and astro are 13/16"..but that's easy to fix. The problem you would have discovered if you read a little is the pitman arm on the older box has a small shaft and will not fit your pitman arm so good luck in finding something that is the right length and design to make it work. There is aftermarket pitman arms for the small shaft but I think they are only made for f bodies and they are about $200. And I don't know why your concerned with a 3/4 turn difference with lock to lock between the two boxes. Most guys like the slower box so if they get into trouble they don't over correct.
