I installed a S10 manual trans tilt g-body steering column custom column. What is everyone doing about reverse lights wiring?
You can use the switch on the transmission then. It's just a matter of extending and routing the wiring from under the dash.LT1 t56 trans I'm using
I'm using a Saginaw with the side cover that has the built in switch mount & using a repop harness. What transmission are you using?
I got it from OPGI & it was made by M&H Electric Fabicators. It's the correct OE style harness.Where did you get the re-pop harness? Is it a “g body with a Saginaw” correct repro, or just a 2 wire harness you rigged up?
