s10 wheel cylinders
Power to manual Brake conversion for 85 GP to S10 m/c??
Hello,
I have been searching for the correct answer on this Brake swap.I have seen you post many times over the last 3 days and see you trying to help out others,and You have a lot of knowledge on the different brake systems,THANKS for your help as I am needing to do this as economically as possible and with out buying alot of stuff I really don't need anyway.
OK: here is some background on my car:
85' Pontiac Grand Prix,Drag Race application only,12 bolt rearend-narrowed w/aluminum drums on rear.Front's are all new stock disc brake setup w/line lock.
Here is what I am wanting to Do:
I have read that a cheap upgrade for the wheel cylinder's is the above mentioned wheel cylinder's from the 82'/S10 with manual brakes.Cool got a positive on that one.I am needing to switch from the power brake setup to a manual.Can I just get the manual master cylinder for the 82'/S10 and use it as the donor to bolt into my "G-BODY" stock location/fitment?I have ordered a new push rod already to accommodate the longer need for the manual master cylinder setup.If so I will be very happy!,if not well I will get a good lesson in what/how to Do It.Thanks in advance for you sharing your information with me.
Jason
pose_442 said:
I believe you're referring to the s-10 without power brakes. These wheel cylinders are slightly larger than the power brake units. This puts more force onto the brake shoes. Usually, these were in the 82-93 S-10's.
To answer your question, I'd tell them 82 S-10 w/o power brakes.
I did the S-10 wheel cylinder swap in my GN. The only value in it is extra holding power on the line for when you are up on boost or maybe up on the converter with a big block. That is unless you have seriously upgraded the front brakes. Also noteworthy is that you have to adjust the proportioning valve for on the street especially for wet roads as the back will lock before the fronts.
As some of you know, the 78 G's have some different brake components from the 79 and later, but wheel cylinders were NOT different.
