Got Strange to send me the Installation Instruction, where I discovered that I was supplied the incorrect axle retainers. Got ones for drum brakes not the LS1 Disks. Had to buy the correct retainers. So, after machining out my original backing plates to clear the bearings I now have backing plates that are no good. Went to the Pick n Pull and there was a 2001 Camaro with a V6 with the disk set up. I thought only SS/Z289s came with that setup. Took me less than 30 min to pull the axles, remove backing plates. Now need to have the good backing plates installed by having the bearings removed, backing plates slid in and bearings installed. I've ordered new bearings that come with the seal. I messed around so much trying to figure this out that I don't want to risk a seal leak. Pic to follow.
