Saginaw power steering box fittings
81cutlass
4,649
13,565
Western MN
Anybody have a part number for the M16 return side saginaw power steering pump fitting? Really looking for a 90 elbow and would prefer to not go from saginaw O-ring to JIC/AN adapter, trying to go directly from the box to the line. I plan to bring the lines to a local hydraulic shop and have them crimped.
I have the stock 2500hd power steering hoses on my 2+2 and am looking to swap them to something that tucks down better.
I already have the M18 high pressure side designed. I just need a pair of 350240 fittings, one in the back of the pump and one in the box.
The thing I can't find is a 90 degree elbow that goes into the box for the M16 return side. I know they exist (this thread has them) I just can't find the darn part number. The OP just bough them from a shop and looking at the image they are the same as the Gates part #, so I am 99% sure gates makes both.
https://gbodyforum.com/threads/custom-power-steering-lines.79187/
I need an M16 elbow that will allow me to take the big loop out and lay it down instead of up.
This is what I want to do but can't find the dang part number.
81cutlass
4,649
13,565
Western MN
mikester
2,923
3,694
Small town NY
OK maybe I answered my own question?
Edelman 39106 for the M16 return
Gates 350240 for M18 feed
The photo you used is my 81 Malibu. I had a shop crimp the lines that you see there.
When it came time to do my 83 wagon I needed the o ring fittings. The crate motor I bought had the serpentine setup and the power steering pump has metric o ring fittings like you have. I bought a Monte SS box set up for the same fittings.
Now the issues. I couldnt find a 90 degree fitting that could be crimped like the ones on the 81. I used the same fittings that you have shown. The hose shop brazed fittings on the tubes on both lines. Then after I mocked up the hoses I took it a back to them and they crimped everything.
The return line just goes up with a straight crimped fitting and back down to the steering pump line. The GM pump has the line pointing almost straight up unlike the pump on the 81. The pressure line follows the same path as the line on the 81.
Hope all this helps.
BTW, the brazing turns the color of the fittings that you show to a funky tarnished color. I taped the hose off and sprayed all of them with Eastwoods silver cad aerosol paint.
81cutlass
4,649
13,565
Western MN
Awesome, that's what I need to know, probably could have PM'ed you. Your setup is really clean and I like it. Thanks!
Parker has low pressure nylon braid 2200psi rated hydro hose that I've used on trans coolers and power steering in the past and Dad also has a crimper and sleeves to crimp that hose into barb fittings but I'm not sure if it's strong enough for the high pressure side. I can do what you did worst case.
JAMCAR223
1,853
5,507
Houston, TX.
Curious if you figured this out, and what direction you went. I would assume that the Parker hose was sufficient, since the Saginaw pump is generally rated @1100-1200 psi. Can you update us?
I have a Saginaw ( Metric '88 Camaro ) pump, and '87 Monte SS 800 series box, and I would like to custom make my hoses. I'm thinking I need a M16x1.5 o-ring to -6an & M18x1.5 o-ring to -6an for the box, and then another M16x1.5 o-ring to -6an for the pressure side of the pump. Black -6an fittings & black nylon braided hose would be ideal.
9,615
12,684
I used the Edelmann 90 on the low pressure side on my Regal when I added my Borgeson steering box.
