Saginaw power steering pump O-ring fitting
RegalX78
20
41
13
I know there are a ton of threads about the 800 series steering box swap, but I could not find a clear answer.
I have a 1978 Buick Regal a 605 steering box with a early Saginaw power steering pump, (flared fittings and lines) I have bought an 800 series pump, pitman arm and o-ring lines. What pressure line fitting do I need to thread into the back of the pump to accept the o-ring line?
part in question attached.
Thanks
carnutjw
621
1,465
I think you need these-
They are made to run a flared fitting box with O-ring hoses I think. I had a similar problem to yours (O-ring box and flared P/S pump). It's been a while, but I think I used only one of these at the pump and new 86 Monte Carlo hoses. Seems like there was something I didn't like about it, like maybe the threads were too long and I cut them shorter??? Been on my car a few years now with no problems.
RegalX78
20
41
13
Those look like they are the opposite of what I need. I'd like to not run an adapter and just get the O-ring fitting for the back of the pump if possible. These should be stock on 80's g-bodys?
oldsmobile joe
2,067
3,053
mpls
timo22
550
1,072
St. Louis,Mo
You could always just go to the junkyard and get the fitting off just about any 80’s gm with the later o ring style lines.
timo22
