ok last fall i picked a new 2nd hand set of hooker comp header set from a member here in wisconsin. i had to make a bend in the no.1 primary tube so far so it would clear the engine mount bracket that attaches to the block and had to trim the gaskets that come with the kit to match the exhaust ports in my p&p 441 heads. kit come with the 3/8'' header bolts that have the 6 pt 7/16'' head. some of these bolts mainly the rear 2 by the firewall i cannot even reach with a wrench. only thing i can think of is to lift motor up and out a bit the reach them or bend/cut up a wrench and make a tool to get around the angle to tighten them. its just too close to the header tube to get a box wrench on it. looks like i won't be able to torque all the bolts i guess. what have u guys done? i can use some help 😳
