sbc 350 hooker header help
I brought mine straight up and basically made a loop that is wire tied to the top of the harness and pushed back into the A/C area. They are wrapped in that metal fire protectant tape GM uses. Only have about 50 miles on the swap but so far so good. Still working the bugs out of the brake system.......
tape
did you get this tape from like the dealer or where and about how much did it cost?
I did get it from the dealer yrs ago, no sure what it is called. It was used for the reaclls in the 90's for the Fieros that used to burn up from the heat and the wires. I will look for it again. If you are having some issues with the trans linkages, I did too. I had to cut my shift linkage bar in 3 places to get the geometry to work with the headers. Your best bet is to use a cable only, that also might be tight. I have to do that next.....
Steve
