ok so my buddy has a 327 that we got ahold of that was in good shape but used, it was bored to 60 over. so we order all of the stuff to rebuild it including brand new 60 over coated pistons, they were not too cheap. problem is during his last move he lost the main caps somewhere and they are gone, the machine shop says it will cost like 3-400 dollars to match another set of main caps to it. i have 2 350 blocks sitting here that are still standard bore but could use a bore to be good, question is should we bore one to 60 over and use the pistons we already have or should we go to 30 over and buy another set of pistons. it is cheaper to us to take another block to 60 over and use the kit we have. and for those wondering about a 327 with a 350 block, its a large journal crank so you can use it in a 350 block and still have a 327. one block i have is a 4 bolt main, we could use that and then say we have a 4 bolt 327.....
