sbc headers with 4 speed linkage
chevymontecarlo95
5
sioux city, iowa
Will hooker 2451 headers work with factory 4 speed linkage, and what full length headers will?
Google works
ker Headers 2451 - Hooker Headers Competition Headers Chevy/GM Car Details
Chevy/GM Car Chevy Small Block
Applications Continued:
  • 1978-87 G-Body
  • 1965-89 Full Size Car
    Footnotes:
  • Designed for stock heads with factory straight plugs (4-1/2" plug spacing).
  • Will not fit angle plug heads.
  • Complete exhaust systems can be fabricated using Hooker Mufflers.
  • A/C Requires bracket520-10925drivers side or520-10926passenger side. 1979 and later with short compressor use stock brackets.
  • Applications with oxygen sensors use555-30012for 3'' three bolt flange.
  • The #1 tube (front drivers) has a small dent for spark plug and spark plug wire clearance.
    Accessory Compatibility:
  • Alternator/Generator - Yes, except short water pump engines with drivers side mount will require520-10927and520-10928
  • Power Steering - Yes
  • Power Brakes - Yes
  • Air Conditioning - Yes, may require brackets listed above
  • Smog Pump - Requires modifications
    Transmission Compatibility:
  • Manual Column Shifter - Yes if equipped
  • Manual Floor Shifter - Yes if equipped
  • Automatic Column Shifter - Yes if equipped
  • Automatic Floor Shifter - Yes if equipped
    Included Items Note:Bolts and Gaskets Included, Reducers required
    Port Shape:SAP
    Emissions Compatibility:Not Street Legal Except Pre-1974
