I am assembling a ran jet 350 long block, its basically a vortec 350. I am using the original ram jet cam with stock length pushrods and using 1.6 roller rockers. the roller lifters have been sitting in a container full of oil for 10 years which is when I took this motor apart (been busy with other projects), I have the intake off of the engine so I can visually see the lifter are seated as low as they can be while adjusting. the first 2 cylinders I had no issues, half turn past zero lash and and the lifter compressed with the valve not opening. I get to cylinder 3 and do the same except this time I notice that I am compressing the spring and not the lifter which in turn is opening the valve. i swapped a few lifters around to the same cylinder and seem to have the same issue. i checked for broken springs and they all look fine. its been awhile since I played with a sbc but I have allot of experience with a little higher performance valve train in bbc with my boat engine and I have never noticed anything like this previously. this was a clean lower use engine, it had 300 hours in a boat, extremely clean internally so i wouldn't think that they would be bad. i took one apart and i don't seem to see any issues. i am a little stumped here. if i need new lifters then its whatever but i would rather avoid dropping 100 bucks if i can avoid it. open to thoughts and suggestions
