SBC motor mounts
custom442
1,889
6
Houston
Anyone have a pic of their motor mounts on the frame? (Just the frame mounts please) Or measurements would be nice.
I have these: http://store.summitracing.com/partdetai ... toview=sku
I'm thinking I bought the wrong ones, but to save a huge amount of time mocking up the mounts and drilling, maybe someone has some pictures...
Motor mounts
Moroso 62630 fit G Body frame when in the forward crossmember hole position. They are compatible with 62515 solid engine mount bracket on a Chevy.
The 62630 will overhang the X member when in the correct position.
Do not use a solid trans mount if you have real horsepower.
Use Loctite on all bolts. Bolts and nuts should be grade 8 or 10.9 or better. Torque all bolts properly.
Thanks for the good info. I was planning on using a similar trans mount as stock (something like polyurethane or rubber). This particular part does fit the frame, but not in the bolt holes and the frame needs to be drilled, no big deal though.
The bad news - my th200 doesn't bolt up to the 350 so I'm going to have to wait a month or two before I start it up -- to buy a new/used transmission. :evil:
