1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
SBC motor mounts
Discussion in 'Engine / Swaps etc.' started by bigdawg, Jul 1, 2012.
Thread Status:
  1. bigdawg
    bigdawg Master Mechanic
    Oct 9, 2011
    366
    i cant find the block mount only the frame mount. i bought it from oreilly's the frame mount and cant find the block mount. now i realize they sell moroso mounts but i need frame and block mounts for those to work.
    these look universal and was wondering if i could use them to drop my 350 in my regal
    http://www.jegs.com/i/Quick-Time-BellHo ... ProductId=
  2. bigdawg
    Oct 9, 2011
    366
    well called jegs and they said those dont work, guess im forced to get the moroso set? 70 bucks for mounts holy smokes :shock: it never crossed my mind once that i would have this problem, why do they sell only the frame mounts lol
    theres no way im pulling a motor in the junkyard for those mounts
  3. maliburacinfreak
    maliburacinfreak Master Mechanic
    Oct 7, 2005
    449
    2
    Evansville, IN
    part stores dont sell them because they dont go bad. ill check and see if i have a spare set laying around the garage. if i do, pay shipping and theyre yours.
  4. bigdawg
    Oct 9, 2011
    366
    that would be pretty bad ass, i got the set that came with the 350 vortec out of a suburban but i would have to drill the hole to line up to the frame mount and then after that im sure the motor will sit too high and i dont like cowl hoods
  5. gbondo57
    gbondo57 Greasemonkey
    Aug 30, 2010
    128
    Central Okla/USA
    I could be off, but, the parts I think your looking for are commonly refered to as clam shells. Three bolts to the block, and if your lucky, the long bolt that goes to the frame mount. I got a set from the salvage off on engine on the ground. This set had the long bolt NUT captured on the shell. When installing, make sure you stab the fuel pump side from the back. Putting it in from the front requires pulling the fuel pump to pull it back out. (I.E. you put the bolt in then the pump) If your frame is not quite "perfect" there will be a shimmy shuffle to get the second one in. I had to "butcher" an old frame mount to fit up. Rots oh Ruck, DuDe
  6. chevyfan16
    chevyfan16 Apprentice
    Feb 20, 2012
    87
    Evergreen Park, IL
    Can you post a pic of what you need cuz I think I have a set also and you can have them.
Loading...
Thread Status:
Share This Page
