FWIW, if all you want to do is knock some carbon out of the combustion chamber you can slowly pour water down the carb throat to steam clean the pistons. Don't laugh, it works...and it's free.
DRIVEN said:FWIW, if all you want to do is knock some carbon out of the combustion chamber you can slowly pour water down the carb throat to steam clean the pistons. Don't laugh, it works...and it's free.
yeah my dad said they did it all the time in mexico, but i never heard no one else do it is i never tryed itDRIVEN said:FWIW, if all you want to do is knock some carbon out of the combustion chamber you can slowly pour water down the carb throat to steam clean the pistons. Don't laugh, it works...and it's free.
DRIVEN said:That sounds like a really bad idea and won't make your car run any smoother -- IF your bearings even survive.joesregalproject said:I've also been told to run 3 qts kerosene: 2 qts oil, at idle, for about 5 minutes after the car gets hot, then change the oil, as a sludge removing method. I'm a little to scared to try that one out. I think I'll go with transmission fluid instead.
I've used Seafoam to de-carbon valves and free up stuck rings with varying results. It makes an awesome smoke show. I'd suggest doing it at night if you have neighbors or live near a busy street.
pontiacgp said:I've used the kerosene method and it works without any damage. I've also done the bon-ami treatment to seat rings. I use the transmission fluid in the oil and down the carb to clean both top and bottom of the engine. I have nothing against seafoam except it's price.. transmission fluid is alot cheaper and does the job.
