1986 Buick Regal Limited, 5.0L/307 CI Olds, all stock no modifications. It will gradually get to a point that it is a good running usable mode of transportation. But, over time, it will gradually start to run rough, to the point that it is undriveable. It's like a gradual roller coaster of running good to barely running, usually over a 3-5 month period.
Currently, the only trouble code is 34. I have no idea what this means other than what the Chilton's manual says, which is "Manifold absolute pressure (MAP) sensor output high (after ten seconds and below 800 RPM).
Can anyone elaborate as to what this may mean? I had a spare (new) MAP sensor, so I put it in with no change. The car currently idles ok (for this particular car), but as soon as it is put in drive the RPM drops and the engine starts missing. The engine skips and pops and struggles to get up to 25MPH, and when coming to a stop, it sounds like it is going to stall (but hasn't yet).
Previously, advancing the timing and turning the idle up helped. It still ran poorly, but I continued to drive it and it got better over time to the point that it was running ok. It reached a "peak", then I could gradually feel it missing harder/more pronounced over a week of driving. Now it's back to "don't drive me" mode.
