Glad too hear you got it figured out.For now,it might be better to keep it simple,get it running then experiment with ignition boxes.
You could start with a new rebuild kit for your distributor,like this one;
http://www.summitracing.com/int/parts/p ... /overview/
You can also test the pickup.I copied & pasted this for you;
1.To test the pick-up coil, first disconnect the white and green module leads. Set the ohmmeter on the high scale and connect it between a ground and either the white or green lead. Any resistance measurement less than infinity requires replacement of the pick-up coil.
2.Pick-up coil continuity is tested by connecting the ohmmeter (on low range) between the white and green leads. Normal resistance is between 500 and 1500 ohms. Move the vacuum advance arm while performing this test. This will detect any break in coil continuity. Such a condition can cause intermittent misfiring. Replace the pick-up coil if the reading is outside the specified limits.
3.If no defects have been found at this time, and you still have a problem, then the module will have to be checked. If you do not have access to a module tester, the only possible alternative is a substitution test. If the module fails the substitution test, replace it.
If the pick up is bad,you have to take the distributor apart to change it.Not too difficult,just requires time & patience.
Hope this helps.
Guy
