I have a 80 Cutlass its a full body car with a pro/built 461" olds 1050 Dominator stage 2 drag porting done to Torker intake and heads, has eagle crank and Rods. Forged pistons 12.5 to 1 motor on 110 octane has been balanced and has new block and heads from Rocket Racing runs 10.70's off the trailer no spray. Has a built Turbo 400 manual valve body deep pan but no transbrake, car is running a 12 bolt with a spool all moser 4.11 gearing 33 spline axles and C clip eliminators. Has upper and lower control arm upgrades also bags in both coils and a anti Roll set up. Runs on ET Drag 29.5/10.5/15 stiff wall Slicks this car is still over 3550lbs as it sets how much weight can I shed off it. The only thing thats been taken off is the heater box. Still has power windows all stock glass and rear seat has a 6 pt bar and its a hard leaver 1.45 60fts of the footbrake at about 1500rpms I know I can loose the headlites and all hardware running a 8 gal cell in trunk and battery in trunk so stock fuel tank is also gone along with fuel pump, running a Magna fuel 500 pump and filter, electric fan, and electric driven water pump. Also full MSD ignition 6al,coil,Dist how much weight can I get rid of oh I also just put a set of drag buckets in it but the rear seat is still in it. The car haus *ss right now and I do not intend to run it on the street but I do want to keep it Titled. I know if I can remove 750lbs or so I should be real close to a 10 flat car.
