Shifter bushings
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,310
10,148
Gainesville, Fl
Does anyone know here I can find the shift rod bushing for the column lever?...and also looking for the cable grommet that seals the cable access hole in the tunnel. It has two screws holding it down.
Also, if anyone has a cable pin that fits on the end of the cable, in the square slot of the shift selector, let me know. BTW, this is for the stock shifter cable.
Thanks man,
but it's not the oval bushings that I need. It's the one round bushing that fits in the column shift lever.
Anyone??..or am I just pissing in the wind?
Jack, I can send you the bushing from my GP. I don't need it and it was in good shape when I got rid of the rod. I'm talking about the one in the lever that is on the steering column on the engine side of the firewall.
Hey, thanks Steve, I'll let you know. I'm going to check the HELP aisle today. If I don't luck out, I'll drop you a message. 😀
Steve,
That's exactly the one I need. I will accept your offer, knowing that you have no need for it with a standard trans conversion.
The HELP aisle wasn't any help... :?
I'm also looking for the grommet, or a similar grommet where the cable pokes thru the access hole. If you know of any sources for the grommet, let me know. I figured playing with race cars, you'd have a fix on who deals in what.
I'll send you a PM.
Thanks man!
Jack, it's on its way and hopefully it will be there for the weekend.. 😀
for the grommet for the cable I don't have one but all the cars with console shifters us the same grommet. I'd have one if we still raced the G body or F body but we build our chassis now....and that gromet is easier to find on the shelf since it fits sheet metal.
