Show off your engine!
511" BBC Stahl headers yeehaw
L.A.X-RATED said:
Do you know the years vortec engines(5.7)covered? And are they basically the same,parts wise?reason being I just aquired a mcSS with a vortec engine which I believe is a 5.7 from the performance and pep in the step it has,but am not 100% sure an until I pull the engine to get it ready for a tpi swaP I'd like to keep the matineance up and what not,thanks,and sorry for the thread jack :shock:
There was Vortec 350's and 305's. They were in the trucks and vans from 96-00(maybe 02 in the heavier duty stuff). Internally all the 350 should be the same, roller cam, either the 062 or 906 casting head. If you're unsure what it came from, look for the suffix code on the small pad on the block just in front of the passenger side head. One other thing to note is the piston rings are metric(more expensive) instead of standard like the 350's before them.
140 + HP of pure Slug!
Small Block Chevy 350 bored .40 over 11:1 Compression 500 HP
:drool: so clean^^^
No mine but helping on my buddy 86 regal. Supercharged 383
I belive a 172 could be a 177. He bought it used from a Guy who said it was a 17?. There were no part # on it.
