Smog pump removal advice
Fnlowrider
35
36
Myrtle beach
I have a 1987 Caballero 305 and the smog pump has been removed and a dual exhaust has been added without cats I have an electronic distributor and am still using the Factory Rochester carburetor I would like any input regarding components which may or may not still B needed or should be modified such as knock valve EGR or even ECM any input would be appreciated thank you
1320John$$$
951
2,043
Pennsylvania
You got headers on it with the dual exhaust
Old school it with mechanical dizzy and carb
Fnlowrider
35
36
Myrtle beach
No I don't have headers I'm considering a few upgrades and changes headers being one of them but I want to do things in the right order a posi rear end is definitely in the future
1320John$$$
951
2,043
Pennsylvania
Before you go spending money on a Posi rear. Get a good mechanical distributor with vacuum advance and a non-computerized carburetor get the thing running right then go after the converter transmission and rear
Clone TIE Pilot
3,868
2,621
Galaxy far far away
Just put a heated O2 sensor on the headers, the computer will operate fine after that. There are many ways to add O2 sensor bungs onto headers. Removing the computer system will cost $500, decrease MPGs, and no power gain to even power loss. There are much better ways to epend that money. A guy on MonteCarloSS forums sells ZZ4 performance chips for Chevy ECMs for $65. The CCC system can handle over 400 hp, its not gonna hold you back for a street car.
79 USA 1
1,065
2,040
Cheektowaga, New York
Years ago I had a 86 El Camino I swapped a iron headed 355 into with long tube headers twin cats and true dual exhaust. I ran the computer control Q-jet and distributor but used a factory 86 Monte Carlo SS PROM chip in the ECM just due to it having a little different timing curve. Put over 150,000 miles on that engine and never had an issue. The air pump and lines were deleted during the engine swap. I just taped up the connections, bundled up the wires and tucked them into the inner fender.
