I wanted to know if anyone was running their g-bodies this way and what they thought. I aready have solid body mounts and an 8 point cage welded to the frame. I have the UMI lsx swap motor mounts and I have some ls1 camaro clamshells with poly inserts. I didn't get the transmission mount yet, kind of on the fence about running a poly one of those too or getting a solid mount and buying the UMI aluminum clamshell replacements. Anyone that has followed my build knows what I'm going for, but the for the rest, this is a street/strip cutlass with an emphasis on performance. I also want something reliable, and I don't want to be breaking stuff because there is no give anywhere, or if it is better having no give. My buddy has an 82 cutlass he used for hobby stock racing and broke his case on a th350 because he had solid motor mounts and stock rubber trans mounts. I just want to try to eliminate weak links and put the power down on the track.
