Speedo cables 79 elky g body
Did the speedo work prior to you taking it apart, or are you in the midst of troubleshooting it?
You can test the cables using a cordless (or corded) drill.
Yes it worked fine,I looked at them both,the larger one the cable (metal )sticks out but the smaller one (plastic) doesn't stick out much I just may do what you did ,elemate the sys !
I'd say before eliminating the system, try to figure out what's wrong with it. It may be an easy fix. As long as all the components are still there.
Reactions: Texas82GP
iLl play with it tomorrow and see we're it gets me ,thanks !
Reactions: Longroof79
Found transducer is dragging and snapped the cable end (plastic end),took apart lubed still drags,lookin for one now !
