My drive gear is a brown 20 tooth and my driven gear is a red 37 tooth. This transmission is out of a '78 firebird, according to the guy I got it from. I think the engine was a 350 pontiac 2 barrel, but I'm not sure.
I am as well, used the 1000 rule.The calculator has one variable that I can't guess at and that is the speedo rpms per mile. Not knowing what yours is I used 1000 which it says older cars used. If you have a different factor then the ratios would change. What did you use? EDIT: I just looked at my own and there is no number on the speedo face. I am at a loss on that.
