I need some help/advice on a non-working speedometer on my 1981 Malibu. I have a TH350c and the car had a non-working speedo at purchase and I am trying to repair and coming up short.
Stuff I replaced and tried
Different speedometer (yes the cable clip is good and engaged)
New Speedometer cable and lubed
new drive gear housing - TCI
New driven gear (small gear) and new drive gear (large gear)
the speedometer is jumpy but was working but there was high gear noise coming from tailshaft area while sitting in the car driving (sounded like speedometer gear problem.
after it quit working for like the 10th time I pulled the transmission tailshaft and thought there was too much play in the tailshaft also the speedometer drive gears had some minor damage but could be re-used.
I replaced the tailshaft output shaft bushing and replaced tailshaft seal replaced both speedometer gears transmission fluid and filter and tried again.
the speedometer was jumpy then quit after less than a mile.
every time this happens I can pull the speedo cable from transmission and turn it and the speedometer will move - so I'm back to the transmission
ANY IDEA's?
ANY IDEA's?
